Berchtold - Chromophare C571
Dual Surgical LightsThe Berchtold Chromophare model C-571 Surgical Light, which has Dual Heads, is superb for any Surgical Setting. The Berchtold Chromophare has shadow-free illumination with a focusable light pattern. These operating lights have a maximum illumination of 120,000 lux. Instant-on back-up light bulb in case of primary bulb failure and halogen ambience lighting (on back of light head), No Shadows in operating field with a field diameter of 7.1" to 11" and each light head has a diameter of 22.4". Adjustable Intensity (with supplied wall controller). This Major Surgical Lighting System is Completely Refurbished.
1Reply8 years ago | Part # for braided stainless S wires inside Berchtold chromosphere C-571 halogen light I need the Berchtold Part # for the braided stainless wires (3 ea) which carry voltage inside a Berchtold chromosphere C-571 halogen light. The wires come in an S shape and over time the heat breaks down the insulation. Each wire is 3" long; 14 AWG 1015 stainless (30-36 strands/ wire) TEF (rated 105 deg C). Reply |
[list] [*] Freedom from shadows in the operating field [*] High luminous power which generates the high illumination and high colour temperature similar to daylight [*] Easier hygiene due to smooth styling of the light body - the absence of control knobs on the outer surface, and airtight sealing of the light head [*] Larger range of height adjustment; greater mobility of the light [*] Easy replacement of defective halogen bulbs [*] Dual Head [*] Ceiling Mounted [/list]
Bulb Life | 1000 hr |
Depth of Field | 130 cm |
Color Temperature | 4500 K |
Lighthead Diameter | 22.4 in |
Field Diameter | 17 to 28 cm |
