Leica Biosystems - RM2135
by Leica Biosystems
Microtome
The Leica RM2135 Microtome is a classic manual rotary microtome based on 125 years of Leica experience in manufacturing and design. The ergonomical concept of the Leica RM 2135 microtome integrates extraordinary safety standards and user friendly operation. The Leica RM2135 Microtome features cross roller bearings for the horizontal and vertical specimen feed ensure accurate reproducibility of section thickness and optimal section quality.        The Leica RM2135 Microtome features a new patented gravitational force compensation system offsets the centrifugal forces that arise during the sectioning process. The new system ensures a very smooth and easy turn of the handwheel to obtain a uniform stroke for excellent, chatter-free sections. As a result, the smooth running handwheel creates stress-free working conditions and repetitive motion disorders are reduced to a minimum.
FORUMSView All (3)
-Ross
Sat Jul 26 2025
Leica RM2135 handwheel assembly tool
The Leica RM2135 service manual mentions a tool to be used when assembling the handwheel shaft. It applies pressure onto the bearings to enable inserting additional shim washers, to adjust the tension. The service manual calls it p/n 0800, but I am pretty sure that requesting to buy p/n 0800 from Leica (if by some miracle the tool is still available) won't be sufficient. I have never seen one of these tools, but I can envision what it is doing.
Does anyone have more information? A picture or a video of one in use? Reply
-MedWrench Crystalyn
Tue Jun 01 2021
Leica Biosystem RM2135
Leica Biosystems RM2135Reply
3
-janzaldi
Thu Sep 22 2016
RM2135 Main Shaft
We need a service manual or part number for the Main Handwheel shaft and also the part number for the course feed handwheel
VIDEOS
  • Maintenance free cross roller bearing slideways
  • Section thickness settings from 1 to 60 um
  • Mechanical trimming function (10 um and 30 um)
  • Security handwheel can be locked in any position
  • Closed housing, easy to clean
Height12 in
Length 21 in
Weight75 lbs
Width19 in
