Cutting Edge - 20W
by Cutting Edge
20W Ho:YAG Surgical Laser
The Holmium: Yag Surgical Laser delivers energy via fiber for precision lasing from anywhere from 1-20 watts. Because of its extreme precision, it is ideal for both surgery and microsurgery. Because of its low-invasive nature, clients can expect increased efficiency, safety and reduction of healing time, all leading to higher customer compliance. A wide range of fibers (200-365-550-600-1000) makes this an ideal tool for neurology, orthopedics, urology and oncology. Its software can store up to 30 operating protocols. Technical Simplicity and LCD display makes operation and navigation simple.
Laser TypeHo:Yag
Weight198.4 lbs
Wavelength2100 nm
Frequency: 7/10/15/20 Hz      Control Panel: color touch-screen      Emission Control: Continuous/ Pulse burst with auto repetition      Power Supply: 115 Vac/16A(max)/50-60 Hz  Database: 30 Programmable Settings      Aiming Beam: Diode, 5mW(red or green)      Emission Power: 20W      Cooling System: Integrated air/water      Energy: 2J      Pulse Duration: 250-350 Μs      Electronic Control: Microprocessor
