Surgical Laser
The Mphi5 is a complete MLS solution. It combines both the basic hand piece designed for treating a targeted area with precision; and the pantograph arm with multidiode Ultra head used to treat larger areas in a short amount of time, without the need for constant operator assistance.
- Basic Hand Piece:
-1 MLS® laser source, power up to 1.1W
-2 cm target area highlighted by high efficiency red LEDs
- Multi Diode Hand Piece
-3 MLS laser sources, power up to 3.3 W
-5 cm target area highlighted by high efficiency red LEDs
- Back-lit graphic touch-screen display
- Simultaneous management of two independent channels
- MLS pulse modulation frequency from 1 to 2000 Hz with 1Hz steps
- Power levels of 25%, 50%, 75% and 100%
- Fixed or variable duty cycle
- Treatment time from 1” to 99’59” in steps of 1”
- Automatic calculation of the emitted energy according to the set parameters
- Laser emission warning light
- Interlock
- Audible alarm that can be set by the operator
- Date and time functions
- Password for device starting
| Height | 33.5 in |
| Length | 25 in |
| Weight | 55 lbs |
| Width | 21 in |
