International Biomedical - AeroNOx®
by International Biomedical
Ventilator
The AeroNOx® offers continuous and uninterrupted inhaled nitric oxide administration and analysis for all your bedside, transport, and backup needs. Gas delivery has been developed around a mass flow meter with an easy-to-read digital display and is controlled by a high accuracy metering valve. This compact system continuously monitors NO, NO2 and O2 via sidestream analysis and is compatible with most continuous flow ventilators. These features make the portable AeroNOx® system an indispensable tool for inhaled nitric oxide therapy.
FORUMSView All (4)
-Kaiser toolcrib
8 years ago
service manual
do you have a service manual for this unit> (aeronox)Reply
-Michael Cotton
11 years ago
Thermistor Part Number: SL15 30003-L is burt up.
The incubator 3A AC fuse keeps blowing and thermistor Part Number: SL15 30003-L burnt up. I replaced the thermistor but it burnt up again. The controller board is not connected when this happens so I know its isolated to the power supply. Any suggestions? Need help. Is there a service manual available for purchase? Any help would be appreciated.
-medflight
12 years ago
ventilator compatibility
Is the Crossvent 2I+ compatible with the aeronox system?
Height10 in
Length 5 in
Weight10 lbs
Width12 in
