RTI Group North America - Cobia Flex
by RTI Group North America
As compact and flexible as QA can get.
The Cobia FLEX R/F is designed for Rad/Fluoro, Intraoral, and CBCT measurements, providing an easy and efficient solution for routine X-ray quality control. Measure all key X-ray output parameters — kV, dose, dose rate, exposure time, total filtration, and HVL — quickly and accurately.
Building on the simplicity of the Cobia SMART, the FLEX R/F offers greater versatility, including an internal detector, a detector input for external probes and ion chambers, and an optional built-in mAs function. Readings are shown clearly on the large display and can be stored for later review.
With Bluetooth and USB connectivity, Cobia FLEX R/F integrates seamlessly with Ocean Next™ software for enhanced workflow, allowing users to perform remote QA measurements, save and analyze data, and generate professional reports using a laptop or tablet. (Generated by AI)
| Height | 27 mm3 |
| Length | 138 mm3 |
| Weight | 290 g |
| Width | 76 mm3 |
