RTI Group North America - Cobia Sense
by RTI Group North America
Quick and accurate constancy checks
The Cobia SENSE provides a fast, accurate, and flexible solution for routine constancy checks of your X-ray equipment. Designed for use with external detectors, it supports a wide range of probes — including the RTI Dose Probe, Light Probe, RTI CT Ion Chamber, and external mAs probes — allowing for precise measurements across multiple imaging modalities.
With Bluetooth and USB connectivity, the Cobia SENSE integrates seamlessly with Ocean Next™ software, enabling users to perform measurements, analyze results, and generate reports from a laptop or tablet.
Plug n Play Functionality – Simply connect your chosen detector and start measuring immediately. The system automatically recognizes connected sensors, making it ideal for both trained engineers and general clinical users.
Smart Measurement Storage – The Cobia SENSE automatically logs data without requiring resets between tests, allowing technicians to complete all measurements efficiently from the control room.
Optimized for Rad/Fluoro Applications – When paired with the RTI Dose Probe, the Cobia SENSE delivers fast, low-dose rate measurements perfect for Radiography and Fluoroscopy, including tests on image intensifiers. (Generated by AI)
| Height | 27 mm3 |
| Length | 138 mm3 |
| Weight | 290 g |
| Width | 76 mm3 |
