GE HealthCare - Dash 5000
by GE HealthCare
Modular monitoring for flexible care.
The Dash 5000 has a full colour 12.1" TFT Display. Dash 5000 can incorporate the BIS measurement for analysis of hypnotic state. Hardkeys for various functions as patient admission/discharge, trend, standby, auto-NIBD have been added to the new designed keyboard.
FORUMSView All (11)
-CBET Neil
4 years ago
spo2 optionss
How can I tell by looking at this monitor which manufacturer's spo2 cable and patient transducer is needed? Massimo tends to label agressively, not so much with GE and Nellcor. help!Reply
9
-Gallo
5 years ago
Monitor reloops
Has anyone had a Dash monitor turning on and off Reply
3
-LELA
5 years ago
CIC PRINTER LOCATION
Does anyone know how to add a CIC lazer printer to a dash 5000. The one I received only has the printer to that monitor rooms location. I need to add ED CIC lazer Reply
[list]    [*] Design for optimized monitoring in all care applications     [*] Advanced algorithms for all monitored parameters     [*] Fully flexible alarm settings allow personalized monitoring     [*] ECG acquisition through cables or wireless     [*] Bright alarm light at the bedside helps to immediately locate the patient in critical situations     [*] Multiple mounting solutions and a wide range of accessories ensure easy and flexible workplace configuration     [*] 3 waveform screen view to maximize the size of parameter values and waveforms     [*] Convenient care area specific Remote iTouch Pad enables operation on both sides of the patient’s bed and direct access to frequently used functions     [*] Remote Screen through DashPort2 for optimal central overview     [*] CO2 module and extention Rac for additional parameters     [*] Wide array of interfacing options with iConnect solutions     [*] Both mainstream and low-flow sidestream CO2 measurement options for applications from neonatal to adult patients     Optimized for demanding transportation     [*] Light weight, durable, and ergonomic design     [*] Up to 2 Hot Swap batteries for unlimited battery powered monitoring     [*] DashPort2 Docking Station for easy switching between bedside and transport monitoring     [*] Continuous central monitoring during transport through a Wireless Network     [*] Compatible with bed mount for in-hospital transport    [/list]
Display  Size Dash 3000 – 8.4 in., Dash 4000 – 10.4 in., Dash 5000 – 12.1 in.     Type Active-matrix color LCD     Resolution Dash 3000 and 4000: 640 by 480 dpi, Dash 5000: 800 by 600 dpi     Number of traces 7 (maximum)     Number of seconds/trace 4.9 at 25 mm/sec     Sweep speed 6.25, 12.5, 25 mm/sec (with erase bar)        Invasive blood pressure     Number of channels 1 to 4 (optional)     Transducer sites Arterial, femoral artery, pulmonary arterial, central venous, right atrial, left atrial, intracranial and special     Transducer requirements Excitation voltage: 5 V dc ± 0.1%     Transducer output 5 µV/V/mmHg     [i]Input specifications[/i]     Range -25 mmHg to 300 mmHg     Offset ± 150 mmHg     [i]Output specifications[/i]     Frequency response dc to 50 Hz (-3 dB)     Zero balance range ± 150 mmHg     Zero balance accuracy ± 1 mmHg     Zero balance drift ± 1 mmHg over 24 hours     Accuracy ± 2% or ± 1 mmHg, whichever is greater (exclusive of transducer)     Alarms User-selectable upper and lower limits for systolic, diastolic and mean pressures       ECG     Standard leads available I, II, III, V, aVR, aVL and aVF 3 leadwire I, II, or III     5 leadwire I, II, III, V, AVR, AVL, and AVF     10 leadwire I, II, III, AVR, AVL, AVF, VI, V2, V3, V4, V5 and V6     Leads analyzed simultaneously I, II, III and V (multi-lead mode)     Lead fail Identifies failed lead     Alarms User-selectable upper and lower heart rate limits     [i]Input specifications[/i]     Voltage range ± 0.5 mV to ± 5 mV     Signal width 40 ms to 120 ms (Q to S)     Heart rate range 30 to 300 bpm     Input impedance Common mode > 10 MO at 50/60 Hz     Differential > 2.5 MO from dc to 60 Hz     Common mode rejection 90 dB minimum at 50 or 60 Hz     [i]Output specifications[/i]     Impulse response For an impulse of 3 mV applied for 100 ms     Displacement following impulse < 0.1 mV     Slope following impulse < 0.3 mV/s     Frequency response Response of non-permanent displays is limited by resolution to 40 Hz (-3 dB)     @25 mm/s. Specified upper frequency limits may vary by ± 2 Hz.     Diagnostic mode 0.67 Hz (+0.4 dB) to 100 Hz (-3 dB)     For compliance with China 1.0 Hz (+0.4dB) to 75 Hz (-3 dB)     National Standard     Monitoring mode 0.67 (+0.4 dB) to 40 Hz (-3 dB)     Moderate mode 0.67 (+0.4 dB) to 25 Hz (-3 dB)     Maximum mode 5.0 Hz (-0.3 dB) to 25 Hz (-3 dB)     Noise < 30 µV (referred to input)     Pacemaker detection / rejection     Input voltage range ± 2 mV to ± 700 mV     Input pulse width 0.1 ms to 2 ms     Rise time 10 µs to 100 µs     Over/under shoot 2 mV (max)     Baseline drift < 0.5 mV per hour with a ± 700 mV, 2 ms     Pacemaker pulse Applied       Respiration     Measurement technique Impedance variation detection     Range 0-200 breaths per minute for variations of 1.0 – 10.0 O     Respiration rate 0-200 breaths per minute     Base impedance 100-1000 O at 52.6 kHz     Detection sensitivity 0.4 to 10 O variation     Waveform display bandwidth 0.1 to 1.8 Hz (-3 dB)     Alarms User-selectable upper and lower respiration rate limits, and user-selectable apnea limit       Temperature     Number of channels 2     [i]Input specifications[/i]     Probe type YSI Series 400 or 700 (determined by input cable)     Temperature range 0°C to 45°C (32°F to 113°F)     Resolution ± 0.1°C     [i]Output specifications[/i]     Parameters displayed T1, T2     Accuracy (independent of source) ± 0.1°C for YSI series 400; ± 0.3°C for YSI series 700 probes     Alarms User-selectable upper and lower limits for T1, T2       Cardiac output     [i]Input specifications[/i]     Probe type In-line or bath probe     Catheter size 5F, 6F, 7F, 7.5F and 8F     Injectate volume 3, 5 or 10 cc     [i]Output specifications[/i]     Parameters displayed Cardiac output, blood temperature, injectate temperature and trial number     [i]Range[/i]     Cardiac output 0.2-15 (liters per minute)     Blood temperature 30-42°C     Injectate temperature 0-30°C     [i]Accuracy[/i]     Cardiac output ± 5%     Blood temperature ± 0.2°C     Injectate temperature ± 0.3°C     Frequency response dc to 15 Hz ± 2 Hz       Pulse oximetry     Parameters monitored Arterial oxygen saturation (SpO2) and peripheral pulse rate (PPR)     SpO2 range Nellcor 1-100% Masimo 30-100% GE Ohmeda 30-100%     PPR range Nellcor 20-300 BPM; Masimo 25-240 BPM; GE Ohmeda 30-250     Accuracy Actual accuracy depends on probe. Please reference     manufacturer’s specifications.     Nellcor SpO2 ± 2 digits (70-100% SpO2)     Masimo SpO2 ± 2% Adults/Pediatric (70-100% SpO2)     GE Ohmeda SpO2 ± 2% (70-100% SpO2), SpO2 ± 3% Neonates, = 69% unspecified     PPR ± 3 beats per minute     Alarms User-selectable upper and lower limits for SpO2 and PPR       DINAMAP non-invasive blood pressure     Technology DINAMAP® classic and SuperSTAT™ (SuperSTAT only     available with Masimo and Nellcor SpO2)     Measurement technique Oscillometric     Displayed parameters Systolic, diastolic and mean pressures, time of     last measurement     Measurement modes Adult ICU and OR modes; manual, auto and stat,     neonatal mode; manual and auto     [i]Systolic[/i]     Adult 30-285 mmHg     Pediatric 30-235 mmHg     Neonate 30-140 mmHg     [i]Map[/i]     Adult 20-260 mmHg     Pediatric 20-220 mmHg     Neonate 20-125 mmHg     [i]Diastolic[/i]     Adult 10-220 mmHg     Pediatric 10-210 mmHg     Neonate 10-110 mmHg     [i]Pulse rate, as displayed in tabular trends or 3 wave form display[/i]     Adult 30-200 bpm     Pediatric 30-200 bpm     Neonate 30-200 bpm     [i]Other specifications[/i]     Overall system accuracy Meets or exceeds SP 10-1992 AAMI standards     Automatic cycle times 0-4 hours     Tubing length 12 feet adult, 8 feet neonatal     Automatic cuff deflation Cycle time exceeding 3 minutes (90 seconds neonatal),     French mode – Cycle time exceeding 2 minutes (60 seconds     neonatal), power off, or cuff pressure exceeds 294 mmHg     (± 6 mmHg) adult, 250 (± 5 mmHg) pediatric,     147 (± 3 mmHg) neonatal     Cuff sizes Thigh, large adult, adult, small adult, child, infant and     neonatal, sizes #5 - #1 and assorted long sizes     Alarms User-selectable upper and lower limits for systolic,     diastolic and mean pressures       CO2     [i]Technology[/i]     Supports Novametrix CapnoStat (mainstream) and CapnoFlex LF (low-flow sidestream) CO2 technologies     Principle of operation Non-dispersive infrared (NDIR) single beam optics,     dual wavelength and no moving parts     Warm-up time 2 minutes warm-up time to meet accuracy specifications; waveform immediate     upon power up, calculated end tidal after two breaths     Cable length (mainstream) 8 foot (2.4 m)     Sample line length (low-flow sidestream) 7 foot (2.1 m)     [i]Information displayed[/i]     Inspired and expired CO2 concentrations in %, mmHg or kPa; respiratory rate, continuous CO2 waveform     [i]Measurement range (at 760 mmHg at an ambient temperature of 25°C)[/i]     0-100 mmHg, 0-13%, 0-12.5 kPa     PiCO2 /FiCO2 0-50 mmHg, 0-6.5%, 0-6.25 kPa     Respiration rate range Low-flow SS 0-150 breaths/min     Mainstream 0-120 breaths/min     [i]Accuracy (at 760 mmHg at an ambient temperature of 25°C)[/i]     MS ±2 mmHg or 5%, whichever is greater     SS 0-40 mmHg ± 2 mmHg; 41-70 mmHg ± 5% of reading;     71-100 mmHg ± 8% of reading; all specifications ± 12%     of actual from 80-150 BrPM     Display resolution 1 mmHg     Rise time Less than 200 ms (low-flow sidestream); less than 60 ms     (mainstream adult reusable or SPU); less than 50 ms     (mainstream infant reusable or SPU)     Respiration rate accuracy ± 1 breath/min     [i]Compensations[/i]     Automatic barometric pressure ± 25 mmHg from 530-785 mmHg     Operator-selectable O2/N2O compensation     [i]Calibration[/i]     Mainstream No routine user calibration required. 15 second airway adapter zero performed     when changing to a different style of airway adapter.     Low-flow sidestream No routine user calibration required     [i]Airway adapters and sample lines – mainstream (airway adapters)[/i]     Types Adult reusable (standard), adult disposable, infant     Deadspace Adult reusable/disposable < 5 cc     Infant disposable < 1 cc     Taper meets ISO 5356-1     [i]Low-flow sidestream airway adapters[/i]     Types Adult reusable (standard), adult disposable, infant     Deadspace Adult reusable/disposable < 7.3 cc infant disposable < 1 cc     Adult, pediatric and infant Nasal CO2 and nasal CO2/O2     Adult and pediatric Nasal/oral CO2 and nasal/oral CO2/O2     [i]Alarms[/i]     CO2 High inspired CO2; high/low expired CO2     Respiratory rate Adjustable high and low       Paper recorder     Method Thermal dot array     Horizontal resolution 480 dots/in. @25 mm/sec.     Vertical resolution 200 dots/in.     Number of waveform channels four     Paper width 50 mm (1.97 in.)     Paper length 30 m (100 ft.)     Paper speed 0.1, 0.5, 1, 5, 10, 12.5, 25 and 50 mm/sec. (± 2%)       Analog output     [i]ECG[/i]     Gain 1 V/mV ± 10%     DC offset ± 100 mV (max)     Noise < 5 mV peak to peak 0-300 Hz     Frequency response Refer to frequency response section under ECG     [i]Blood pressure[/i]     Gain 10 mV/mmHg ± 2%     DC offset ± 20 mV (max)     Noise < 5 mV peak to peak 0-300 Hz     Frequency response dc to 50 Hz-0/+2 Hz       Wireless LAN     Operating frequency 2.4 to 2.5 GHz     Transmit power 100 mW     Data rate (802.11) 1Mbps and 2Mbps per channel; (802.11b) 1, 2, 5.5, 11 Mbps     Radio technology Frequency-hopping spread spectrum     Communication protocol IEEE 802.11 or IEEEE 802.11b     UL 1950 Listed (ITE 9B97), CE Mark RF Standard     US/CAN FCC Part 15 Class B, RSS-210, Europe: ETSI EN 300 328, Japan: RCD STD-33R       Battery     Battery type Exchangeable Lithium-Ion     Maximum number of batteries 2     Voltage 11.1 V (nominal)     Capacity = 3.45 Ah (varies with manufacturers)     Charge time Less than 4 hours each     Run time 4 to 5 hours     Battery life 500 cycles to 50% capacity       Environmental specifications     Power requirements 90-132 VAC 50/60 Hz 2.0A, 190-264 VAC 50/60 Hz 1.0A     Power consumption 75 W (fully loaded)     Cooling Convection     Heat dissipation 240 Btu/hr.    Storage conditions     [i]Do not exceed[/i]     Maximum 70°C (158°F) at 95% relative humidity     Minimum -40°C (-40°F)     CO2 sensor -30 to 65°C (-22 to 149°F)     Batteries -20 to 60°C (-4 to 140°F)     Physical specifications     Height Depth Width Weight*     Dash 5000 28.7 cm (11.3 in.) 23.9 cm (9.4 in.) 30.7 cm (12.2 in.) 6.4 kg (14 lbs.)     Dash 4000 27.4 cm (10.8 in.) 24.3 cm (9.6 in.) 29.3 cm (11.5 in.) 5.5 kg (12.2 lbs.)     Dash 3000 26 cm (10.25 in.) 20 cm (8 in.) 28 cm (11.0 in.) 5.2 kg (11.2 lbs.)       Operating conditions     Ambient temperature 0-40°C (32-104°F) (Nellcor 0-35°C (32-95°F))     While charging batteries 0-35°C (35-95°F)     CO2 sensor 10-40°C (50-104°F)     Relative humidity 5-95% @40°C     Vibration MIL-STD 810E, Method 514.4, Category 1     Altitude -273 m to 2,943 m (-896 to 9,655 ft.)
