Monark Exercise AB - 828E
by Monark Exercise AB
Cardiac Rehab/Physical Therapy unit
Monark Ergomedic 828E is the successor to the 818E. The bicycle has a new softer design, a completely housed 22 Kg (48 Lbs.) flywheel and strengthened frame. A new electronic instrument shows effective output in watts and heart rate using telemetry. The Monark pendulum balance ergometer is the world’s most used test cycle for fitness testing. Electronic meter that shows pedal-turns per minute, heart rate in beats per minute, cycling-time in minutes and seconds, intended cycling speed in km/miles per hour, plus distance covered in km/miles. In addition braking power can be set, giving a reading of calorie consumption and power in watts. The pendulum balance is easy to calibrate. Braking of the wheel takes place mechanically via a belt that runs round the rim of the wheel. The two ends of the belt are attached to a revolving drum to which a well-balanced pendulum is fixed. This arrangement works as a pendulum balance which measures the difference in pulling power on the two ends of the belt. Pendulum scale, easy to calibrate. Adjustable seat height. Adjustable handlebar with quick release lever. Stable frame, solid steel tube. Power painted. Wheels for easy transport. Chestbelt and PC Software are included for accurate fitness tests.
  • Pendulum scale, easy to calibrate
  • Adjustable seat height
  • Adjustable handlebar with quick release lever
  • Stable frame, with square tubing
  • Powercoated frame
  • Wheels for easy transport
  • Electronic display with heart rate
  • Chestbelt and PC Software included
Height44 in
Length 44 in
Weight115 lbs
Width21 in
User Weight Limit: 550 Lbs. (249.15 Kg)
Bike Type: Upright
Resistance Type: Flywheel
Display: Time, Speed, Distance, RPM, HR, Calories, Watts
