HP - Marquette Mac Vu
by HP
Marquette MAC VU Electrocardiograph
The Marquette MAC VU electrocardiograph is a multi-function electrocardiograph that has the ability to record and store standard 12-lead adult, pediatric and vector electrocardiographs. This quality unit is a battery-powered electrocardiograph that can record, display, print, store and transmit up to 15 channels of ECG data. This data is analyzed using Marquette Electronics 12SL ECG analysis program and can be printed in a variety of report formats. The MAC VU electrocardiograph’s built in screen displays ECG information and allows the user to select different functions.
- Engineer king David
Mon Mar 14 2022
EMS ERROR
Good day my Ecg (HP Marquette Mac Vu) is Display EMS anytime iput it on and doesn't boot afterwards pls I need solutions Reply
[list]    [*] Integrated Cart    [*] Interpretive Option -Adult and Pediatric.    [*] Automatically adjusts based on age entry    [*] 12 lead AM-4 Patient Module with Full set of patient Leads and Alligator Clip's    [*] High Resolution 10" CRT    [*] Llarge Monocrome Preview Screen    [*] Built in Fax/Modem    [*] Built in Printer    [*] Internal Battery    [/list]
Height43.75 in
Length 33 in
Weight115 lbs
Image Display10 in diagonal
Width17 in
[list]    [*] Display type: High resolution, raster written CRT    [*] Frequency response: 0.01 Hz to 40 Hz    [*] Number of traces: 3, 6, 12 or 15    [*] Processing ECG Analysis Frequency 500 samples per second    [*] Preacquisition: 10 seconds of instantaneous ECG acquisition, analysis and printing    [*] Digital sampling rate: 4000 samples per second    [*] ECG storage: removable media    [*] Technology: thermal dot array    [*] Resolution: 1000 dpi (horizontal at 25 mm/sec), 200 dpi (vertical)    [*] Frequency response: 0.01 Hz to 150 Hz    [*] Number of traces 3, 6, 12, 15    [*] Sensitivity: 2.5, 5, 10, 20 and 10/5mm/mV    [*] Chart speeds: 5, 12.5, 25, 50 mm/s    [*] Power requirements 100/120 VAC ± 10%, 50/60 Hz    [*] Patient Info: Name, ID no., age, sex, height, weight, race, room, date, location, time, medication    [/list]
