Stephan - ARTEC
by Stephan
The modular, efficient anesthesia system.
In close cooperation with renowned physicians at home and abroad, F. Stephan GmbH has succeeded in the on-going development of an anaesthesia system which fulfils all possible requirements in terms of reliability, robust design and efficiency. ARTEC stands out particularly with its clear operation concept and modular structure which permits an optimum configuration for every specific requirements profile. A proven concept which can be combined with the oxygen generator STAXEL for fully autonomous operation, with its own oxygen and AIR generation. Whether for daily use in hospitals or for crisis and disaster regions, ARTEC guarantees outstanding results and is almost indestructible.
The ideal addition to the anaesthesia system ARTEC which can be equipped with an internal battery as optional feature, is the ventilator ABV-U with a large number of ventilation possibilities and safe monitoring of stenosis, disconnection and power failure. Other almost indispensable components for optimum patient care include the anaesthesia gas monitor NGM 1000 together with an O2 and volume monitor, each with adjustable alarm limits.
0Replies8 years ago | Mustafa The Green Ballow deshapes when unit is operating. What will be the solution for this problem? Reply |
3Replies10 years ago | anaesthetic apparatus anesthetic apparatus that has oxygen concentrator built in suitable for low income countries Reply |
Height | 55 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 24 in |
Weight | 187 lbs |
Width | 30 in |
Power supply
Mains 230-115 V AC, 50-60 Hz, 80 VA
Optional
Battery 12 V DC, ca. 45 min.
Gas supply
AIR 3-6 bar + 0,5 bar
O2 3-6 bar + 0,5 bar
Optional
N2O 3-6 bar + 0,5 bar
AIR 1,5 bar + 0,5 bar
O2 1,5 bar + 0,5 bar
Ventilation system
Dimensions 500 x 650 x 130 mm (WxHxD)
System semi-open Ventilation with constant volume
Weight 7 kg (without soda lime)
Absorber volume 2 x 0,9 l
APL valve 0 ... 70 cmH2O
Monitoring
Ventilation pressure Pressure gauge
Volume Haloscale volumeter
Optional
Volume MV, VTe, Flow, Frequenz
FiO2 Visual, acoustic
• Monitoring
Alarms Visual, acoustic
Pressure Pmax
Optional
Volume MV, VTe
FiO2
Sensors
Flow/volume Heated wire anemometer
FiO2 El.chem. oxygen cell
1MPG = German abbreviation for Medical Devices Law
