GE HealthCare - SEER Light
by GE HealthCare
GE SEER Light Compact Digital Holter Recorder
Weighing only 72 grams, the SEER Light Ambulatory ECG Recorder is GE’s smallest and lightest Holter solution—engineered for maximum patient comfort, long-term durability, and reliable cardiac data acquisition. Despite its compact size, SEER Light delivers 24 hours of full-disclosure ECG recording across 2–3 channels, including pacemaker pulse detection for more comprehensive arrhythmia assessment.
Built for clinical precision, the SEER Light utilizes high-quality signal processing to minimize artifact, ensuring accurate data capture even during patient movement. Its lightweight, low-profile design improves patient compliance, while its robust construction supports long-term use in demanding clinical environments.
For biomedical engineers, the SEER Light provides a compact, reliable, and technically advanced ambulatory monitoring solution that integrates seamlessly into modern ECG workflow systems—supporting efficient analysis, streamlined data management, and superior diagnostic confidence. (Generated by AI)
Powered by Froala Editor
[list]    [*] Small, compact and lightweight design makes it more comfortable and convenient for patients    [*] Get 2 or 3 channels of full-disclosure ECG    [*] Get up to 24 hours of recording time with SEER Light and up to 48 hours of recording time with SEER Light Extend    [*] Integral pacemaker detection helps decrease the need for a separate dedicated pacemaker recorder    [*] Easy-to-find event button means the patient can easily indicate whenever a cardiac symptom, such as syncope, palpitations, dizziness, chest discomfort or shortness of breath, has occurred    [*] Onboard memory with solid-state technology for reliability and durability.    [*] SEER Light Extend Controller allows for quick initial hookup with access to patient demographic data and visual confirmation of correct lead placement    [*] Completed data uploaded to GEs MARS* workstation via SEER Light Direct Connect cable    [/list]
EKG/ECG TypeHolter
Height2.1 in
Length 0.6 in
Weight72 g
Width3.3 in
[list]    [*] Digital sampling: 125 sps     [*] A/D conversion: 10 bit, 8 ms sampling     [*] Digital storage: 20 ΜV/LSB     [*] Input level: 16 mV p-p     [*] Frequency response: 0.05 Hz to 40 Hz     [*] Input impedance: 10 MΩ     [*] Safety: Type 13    [*] Storage: medium     [*] Memory: 32 MB     [*] Movement level: 1 channel Pacemaker pulse: 1 channel     [*] Pacemaker detection channel: CH1    [/list]
