GE HealthCare - Marquette Case
by GE HealthCare
The CASE Exercise Testing System enhances productivity and performance with advanced cardiac assessment tools and connectivity options. (Generated by AI)
Powered by Froala Editor
2RepliesTue May 11 2021 | parts finding help needed what is the part number for the recorderReply |
Industry-leading algorithms for rapid, accurate evaluation of cardiac function during exercise.
Expanded networking: Connect via LAN to store patient data and test results in a central database. Physicians can review, edit, and print remotely, improving lab efficiency.
Digital workflow integration: Seamless connectivity to EMR, PACS, and MUSE Cardiology Information System.
Scalable solution: Works as a standalone system, multiple workstations, or a full enterprise solution to fit current and future needs.
(Generated by AI)
| EKG/ECG Type | Stress |
| Height | 63 in with 17 in monitor installed |
| Length | 34 in |
| Weight | 150 lbs |
| Width | 30 in |
[list] [*] Writer Technology: Instant load, thermal dot array; [*] Writer leads: 3,6,12 or 15 leads (standard, NEHB, Cabrera, configurable); [*] Writer speeds: 5, 12.5 25 and 50 mm(sec (+2%); [*] Writer sensitivity/gain: 2.5, 5, 10 or 20 mm/mV (+5%); [*] Writer resolution: Horizontal 1000 lines/sec x 200 dpi dedicated local printing. 200 x 200 dpi generic printing; [*] Paper type: Thermal, perforated, fan fold, 300 sheets/pack; [*] Paper size: A size 214.63 x 280 mm (8.45 x 11 in) A4 size 210 x 297,5 mm (8.27 x 11.7 in) [*] Power supply: AC operation only; Operation voltage range: 90-135 VAC, 45-63 Hz, 2.8 A; 180-270 VAC, 45-63 Hz, 1.4 A; Power consumption: 350 W max (1200 BTU/Hr) <250 W normal (850 BTU/Hr) <30 W standby (100 BTU/Hr) [/list]
