Forest Medical LLC - Trillium 2000
by Forest Medical LLC
Trillium 2000 Holter Recorder
Trillium 2000 Holter Recorders allow quick and easy on-site Holter monitoring capabilities to your practice.        Trillium 2000 Holter Recorders can be combined with our Trillium Silver™, Trillium Gold™ or Trillium Platinum™ Holter Analysis Software to form a complete Holter Monitoring System that    is easy to use. All of our compatible software provides fast and accurate Holter analysis and reporting.
[list]    [*] Enhance Patient Retention - The diagnostic quality reports produced on-site by our Trillium 2000 based Holter Monitoring Systems can help you to determine if a referral to a specialist is actually required. Reducing the number of unnecessary referrals enhances patient retention while improving patient service through faster turnaround times, fewer visits, and broader point of care offerings. Improving patient retention rates can help you to maintain and build your practice while increasing your bottom line.[/list]
EKG/ECG TypeHolter
Height3.5 in
Length 6.4 in
Weight305 g
Width0.9 in
[list]    [*] Channels: 2 or 3    [*] Recording Time: 24 Hours     [*] Recording: Continuous (Full Disclosure)    [*] Memory: Non-volatile Flash-Card    [*] Resolution: 8 – 12 bit sampling    [*] Sample Rate: 256 samples per second per channel    [*] Frequency Response: 0.05 Hz – 100 Hz    [*] Gain Settings: Automatic per channel    [*] Power Requirements: (3) AA Alkaline IEC-LR6    [*] Operating Temperature: 32° F to 113° F (0° C to 45° C)    [*] Non-operating Temperature: -4° F to 149° F (-20° C to 65° C)    [*] Operating Humidity: 10% to 95% (non-condensing)    [*] Non-operating Humidity: 5% to 95% (non-condensing)    [*] Patient Cable: 5 or 7 Lead    [*] Signal Verification: Multi-color LEDs and Test Strips    [*] Three button operation with 16 character LCD display    [*] Time and Parameter Settings: 5 Year    [*] Lithium battery backup    [*] Meets the ANSI/AAMI standard for ambulatory electrocardiographs (EC38)    [/list]
