Nuvo - V7
by Nuvo
The V7 is a mobile operating table, with a modular table top that can be configured to suit each surgical procedure and patient in the best possible way. The V7’s electro-hydraulic adjustments are controlled via user friendly hand- or foot control units or wireless IR remote control unit. The operating table is ergonomic, easy to use and maintain.
0RepliesThu Nov 17 2016 | Nuvo V7 OR table & Stryker Vertier I have a Stryker Vertier table mfg. in 2008...is the Nuvo model V7 identical to it? My question is because I want to determine if parts for future support will be available? THANKS! Reply |
[list] [*] Heavy-duty 1080 lbs. max. capacity with safe working load of 716 lbs (325 kg.) – non-sliding top or 600 lbs. (275 kg.) with sliding top. [*] The floor-lock system keeps the table stable and level with four hydraulic cylinders. [*] Modular construction and easy latching mechanism make setting up for specialties quick and simple. [*] Pre-programmed positions: Flex, Reflex and Customizable Beach Chair plus Memory 1 (M1) and Memory 2 (M2) customer specific programmable positions. [*] The built in X-ray channel and C-arm capabilities are unmatched through the superior materials and wide table top sliding possibilities. [*] Ergonomic and easy to clean The V7’s integrated shoulder chair, with detachable back rest, belt system and head support make the step up quick and easy. [/list]
