Xavant Technology - STIMPOD NMS 450
TENS unit
The STIMPOD NMS450 Nerve Stimulator includes a Tri-axial accelerometer which provides real time feedback of the strength of contraction of the affected limb (Train Of Four, Double Burst and Post Tetanic Count modes only). The strength of each measured contraction is displayed graphically and the relevant ratios are calculated and also displayed. The fine movement diffences that can be detected by utilizing accelerometry offers major advantages over gauging contraction strength visually or tactilely. Tri-axial accelerometry calculates the movement vector of the contraction in three dimensions. This negates the need for calibration as is the case with one-dimensional accelerometers, and reduces the setup time of the procedure. Auto sensing technology provides a solution for simultaneous nerve mapping and nerve location. The Stimpod monitors whether the mapping probe or needle touches the patient and adjusts the current range accordingly, ensuring quick and precise nerve location. This technology provides a cost effective alternative to ultrasound techniques for determining anatomical deviations prior to needle insertion. The technique reduces the time of the procedure and provides favourable patient comfort and safety.
SERVICE COMPANIESView All Electrotherapy Companies
[list] [*] Nerve Mapping Probe - The Stimpod Nerve Mapping Probe was designed to enable transcutaneous nerve mapping at higher currents (to a maximum of 20mA), whilst the tip offers a contact surface small enough to ensure effective discrimination. [*] Charge Transfer Waveform - The STIMPOD displays real time graphical representation of the actual waveform delivered. [*] Proximity Indicator - Visual and audible feedback is given when the target current- and pulse width ranges are reached indicating probable nerve proximity. [*] Non-Linear Current Adjustment - In this current adjustment mode the user can pre-program 20 different current and pulse width settings. [/list]
Transcutaneous electrical nerve stimulation (TENS) | YES |
Height | 145 mm |
Length | 90 mm |
Neuromuscular Electrical Stimulation (NMES) | |
Width | 30 mm |
Current Range - Nerve Locating: 0.0 - 5.0mA - Nerve Mapping: 0 - 20mA - NMBA Monitoring: 0 - 80mA Load Impedance - Nerve Locating: 0 - 20kΩ (100V) - Nerve Mapping: 0 - 20kΩ (400V) - NMBA Monitoring: 0 - 5kΩ (400V) Stimulating Modes - Train-of-Four (TOF) - Double Burst (DB) - Post-Tetanic-Count (PTC) - Tetanus (TET) - Twitch (1Hz, 2Hz, 5Hz)
