Masimo - ISA Capnography
Carbon Dioxide Monitor
The Root® patient monitoring and connectivity platform is expandable with the ISA™ CO2 module for your capnography monitoring needs.
0Replies5 years ago | Anybody done a calibration on one of these crazy things? Anyone out thre done a calibration on these? What is the procedure to calibrate it? what needs to be in gas besides CO2? Reply |
- Nomoline™–No moisture sampling lines and non-proprietary cannulas
- Reduces disposable costs through:
- Extended monitoring time in low- and high-humidity environments
- Use of non-proprietary cannulas
- Innovative design eliminates the need for a water trap
- Patented design allows water in the sampling line to evaporate into the surrounding air, while leaving oxygen, carbon dioxide, and anesthetic gases unaffected
- Hydrophobic liquid and bacteria filter protects the ISA module from bacteria and water intrusion to maintain continuous performance
- Displays end-tidal carbon dioxide (EtCO2) waveform and measurements and trends of EtCO2, fractional concentration of inspired carbon dioxide (FiCO2), and respiration rate (RR)
- Indicated for monitoring infant, pediatric, or adult patients in a range of hospital environments including the OR, ICU, and medical-surgical units
- Requires minimal warm-up time
- Easy to maintain with automatic calibration performed at startup and once every 24 hours
- Designed for low tidal volumes with high breath rates for a wide range of clinical applications
- External module enables easy movement for use on any Root monitor
