Datex Ohmeda - Compact Anesthesia Monitor
by Datex Ohmeda
Compact Anesthesia Monitor is all you need for effortless patient monitoring in post-anaesthesia care and general anaesthesia – a full range of monitoring parameters, intuitive use, carestation configurability, transparent device integration and data transfer between care areas. Coupled with the iCentral suite of applications, iPON information access and iConnect interfacing, modular monitoring is the solution for all your needs.
2RepliesFri Apr 11 2014 | we just aquired Datex S5 compact with MCAiO module, I cannot find way to select unaesthetic agent on main selection Reply |
1ReplyTue Aug 02 2011 | Service Manual for Datex Compact Looking for a service manual for a Datex Compact monitor, unit not booting up, hear the fan spin then stop and no display. DanReply |
[list] Modular, flexible and easy to use [*] The intuitive user interface provides all the monitoring information you need to gain a full understanding of your patients. [*] Wide variety of single and multiparameter modules offers flexible and advanced monitoring capabilities [*] Automatic adjustment of displayed data to maximize the size of values and waveforms [*] Intelligent alarm system offers preset alarm limits for different parameters and adjusts the alarms in critical situations by sensing the duration, severity and the combination of different alarms [*] Remote iTouch Pad for easy access saving time and effort Versatility throughout the hospital [*] The parameter modules, standardized GE connectors and accessories allow care continuity and swift transfer of patients between care areas. [*] Optional E-PSM patient side module travels with the patient to the next care site saving time and effort [*] Seamless data continuity between all care areas with data card, Network, and iCentral [*] Compact and integrated wireless – turn any bed into a monitored bed in seconds [*] Built-in battery and handle for intra-hospital monitored transfer with a variety of mounting options [*] Device Interfacing Solution support for other patient care devices brings information to the Compact Monitor display screen and on the network [*] It can be used as a standalone monitor or together with any ventilator. With the Device Interfacing Solution, iDIS, it provides unique value by integrating ventilator and monitoring data [/list]
| Height | 340 mm |
| Length | 205 mm |
| Power Requirements | 100-240 VAC |
| Weight | 11 kg |
| Width | 335 mm |
Display Display size 12.1 inch diagonal Display type Active matrix color TFT LCD Display resolution SVGA resolution, 800 x 600 Number of waveforms Up to 8 Number of digit fields Up to 4 Display layout and colors User-configurable Integrated Command Board with direct function keys, menu keys and ComWheel™ for selections and adjustments in menus.
