Edwards Lifesciences - Vigilance II
by Edwards Lifesciences
The Vigilance II monitor gives you the ability to present complex hemodynamic data in a simplified way.
The Edwards Lifesciences Vigilance II monitor, when used with a Swan-Ganz advanced technology pulmonary artery catheter or an Edwards oximetry catheter, provides a continuous and comprehensive view of hemodynamic performance - offering you a solution for your critical and most complex patients.                The Vigilance II monitor gives you the ability to present complex hemodynamic data in a simplified way to paint a clearer picture of the patients hemodynamic status.
FORUMSView All (9)
-TuukkaTikka
Fri Jul 18 2025
User manual or other help needed
What does this Edwards Vigilance II alarm exactly means? Pressure/CO/TD Bolus Fault- CCO: CCO not configured - R. Heart monitoring unavailable
-Norman Whitaker II
Thu Jul 01 2021
Battery Power?
Are the Vigilance II monitor battery powered? I am asking this because one of the department (at the hospital I work at) sent one of these units down to the shop with the complain of "the unit will not hold a charge."Reply
2
-Brittanymcbath
Wed May 26 2021
SQ squares
We have an ancient machine and no user manual if any kind. How are we supposed to interpret the SQI squares in the top right corner of the screen? The 4 boxes that are either green, yellow, or red?Reply
  • Continuously displays cardiac output (CO), SvO‚, EDV, SVR, and other measured and calculated hemodynamic parameters on customizable screens
  • On-screen trend, relationship, and STAT displays provide a comprehensive view of blood flow and tissue oxygenation for informed patient management
  • Interfaces with compatible bedside monitors to display additional measured and derived parameters, including continuous SVR, DO‚, DO‚I, VO‚, VO‚I, O‚EI, O‚ER, and VQI
  • Serves as an effective educational tool for training clinical staff on advanced hemodynamic monitoring principles
Height9.5 in
Length 8.17 in
Weight3.43 kg
Width11.5 in
TFT Display
  • Active display area: 8.3 × 6.2 in.
Trend Display
  • Configurable trend history from 30 minutes to 24 hours
  • Displays up to 4 large parameter frames simultaneously
NEWSView All
Product Showroom: Critical Care Monitors
This month, Medical Dealer explores current trends in critical care monitors.
