Bionet - CardioTouch 3000-S
by Bionet
The CardioTouch 3000-S provides a large LCD display and touchscreen operation. It is the most efficient and cost-effective 12 channel resting ECG and spirometer combination unit. ECG reports, including detailed interpretation information, print on A4 full size paper for easy filing. CardioTouch 3000-S stands out for its high functionality, user friendliness, and an unbeatable price/performance ratio. SPM-300 uses a disposable sensor, so it is very easy to maintain because the sensor does not need to be disinfected between uses. These disposable sensors make an accurate measurement possible every time.
[list] [*] Clinically Important Simultaneous 12 Lead Acquisition [*] Maximized Ease of Use [*] Built-In Memory [*] Enhanced Interpretation [*] A4 Full Size Paper [/list]
| EKG/ECG Type | Rest |
| Height | 305.5 mm (ECG) |
| Length | 92.5 mm (ECG) |
| Weight | 3.5 g (ECG) |
| Image Display | 480 x 272 mm |
| Width | 269 mm (ECG) |
Hight: 200 mm (Spirometer) Length: 34 mm (Spirometer) Width: 47 mm (Spirometer) Weight: 250 g (Spirometer)
