Biodex - Echo Pro
by Biodex
The Echo Pro Echocardiography Table has been re-engineered with the sonographer in mind. The new ergonomic design provides a barrier-free imaging experience. The result is less sonographer injury and better quality images. Redesigned features make it easier for the sonographer to access the patient from all sides. The new cardiac scanning cushion now drops down and releases from either side of the table with nothing protruding. The sonographer has open access to the left thorax area for an unobstructed apical approach. New side rails are flush to the table and fold completely beneath the table out of the sonographer’s way, eliminating potential obstruction. Patient comfort is assured even during lengthy procedures with our new softer feel, Naugahyde® antimicrobial mattress cover, which also provides protection against bacteria. Add options such as an Articulating Scanning Arm Board or Headrest Extension for easier thyroid and carotid access to configure the Echo Pro to fit your department needs.
5RepliesTue Aug 05 2025 | Parts list or Service manual? Hello, I'm trying to replace one of the smaller parts on the arms. |
2RepliesTue Jun 24 2025 | Squeaking or creaking sound when raise/lower exam table that using hydraulic. We have a Biodex echo exam table that is working well except there is a creaking/sqeaking sound when raise lower the bed. The sound seems to be coming from the hydraulic piston when at certains levels raising or lowering the bed. A new bed is not an option. Thoughts on a minimal amount of white lithium grease to the hydraulic piston? Based on what I read elsewhere on Medwrench, this is not a good choice????? Thank you. Reply |
[list] [*] Ergonomic design helps prevent musculoskeletal injuries – comfortable shoulder, arm and hand positions when scanning [*] Extra wide top with 500-lb patient capacity, suitable for bariatric patients [*] Cardiac drop-down cushion, allows release and return from either side of table [*] Industry’s largest cardiac scanning cutout [*] Fowler positioning, 0-80 degrees, redesigned to accommodate natural body extension and sitting position without slide or shift [*] Height range down to 23″ accommodates wheelchair transfers and those with ambulatory difficulties [*] Motorized height, Fowler positioning, Trendelenburg and auto-level adjustment Naugahyde®, antimicrobial mattress cover with Advanced BeautyGard® provides protection against bacteria [*] Central floor-locking system maintains table stability [*] Durable hand controller [*] Allows seated or standing work positions [/list]
| Length | 15.75 in |
| Width | 9.5 in |
