Draeger - Test Lung
by Draeger
The Dräger SelfTestLung spirometer is designed and tested for use with a wide range of Dräger ventilators for any clinical setting. The design uses advanced carbon fiber, silicone, and polysulfone materials which are rugged enough to stand the test of time while delivering the consistent performance you have come to expect from Dräger. This lightweight lung function tester only weighs 190 grams (0.42 pounds). With the exception of the carbon fiber flap, the Dräger SelfTestLung spirometry tester can be autoclaved at 134°C (273°F). This helps ensure the best possible hygiene and minimizes the possibility of cross-contamination. With nosocomial infections on the rise around the world, this feature supports patient safety. To make cleaning easier, the Dräger SelfTestLung can be completely disassembled in just one step – a real asset in any busy ICU setting. The carbon-fiber flap can be disinfected to support the hospital’s infection control measures.
[list] [*] Approved for use with a wide range of dräger ventilators [*] Ready to autoclave [*] Complete disassembly for easy cleaning [/list]
