Advertisement
BC Biomedical - IPA-3400
Manufactured by BC Biomedical
Compact, full featured four channel analyzer
The IPA-3400 is the most compact, full featured four channel analyzer on the market.
It is a high accuracy, easy to use system that incorporates full touch screen control of all processes without the use of old fashioned buttons and knobs. This new cutting edge Patent Pending design uses a dual syringe stepper motor driven system that provides continuous monitoring of the fluid flow without the need to stop and perform intermittent drains like older technologies do. This provides a more realistic flow path for the Infusion Device under test and therefore more accurate readings. Also, independent stepper motor control of the custom designed ceramic valving allows the system to run not only more quietly and more smoothly, but it also allows for a bidirectional powered fluid flow for use in the built-in cleaning cycle.
QUESTIONS & ANSWERSView All
Be the first to ask a question about this equipment
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
  1. Smaller in Size - Larger in Features
  2. Faster in Operation
  3. Easier To Use
  4. High Accuracy
  5. Large 7” Color Touch Screen
  6. 1,2,3 and 4 Channel Models Available (Field Upgradeable)
  7. User Swappable Fully Self Contained Flow Modules
  8. Calibration in Flow Modules
  9. No Need To be Down For Calibration or Service
  10. Smooth Dual Syringe System
  11. Eliminates Drain Cycle Inconsistencies
  12. Whisper Quiet Operation
  13. Auto Start
  14. Built in Auto Test Sequences
  15. Built in Data Collection
  16. Built in Reports
  17. Industrial Grade SS Pressure Sensor
  18. Performs All IEC 60601-2-24 Required Tests
  19. 10 uL to 1600 mL/Hr
  20. 4 USB Ports, 4 AUX Ports, Plus Bluetooth
  21. Flash Drives, Barcode Scanners, Printers, Keyboard and Mouse Directly Supported
  22. PC Compatible
  23. Configurable Pressure (mmHg, PSI, Bar, kPa)
  24. Large 32GB Internal Memory
Analyzer/Simulator TypeInfusion Device
NEWSView All
!{article.title}
Rice Lake Weighing Systems Awards BC Group for Outstanding Sales
BC Group is proud to announce that it has received Rice Lake Weighing Systems’ Award for Outstanding Sales Performance in 2015.
!{article.title}
BC Group Announces the DA-2006-VL Has Received FDA 510(k) Clearance
!{article.title}
BC Group Announces the Monopolar Handpiece Simulator for ESU Analyzers
The Monopolar Handpiece Simulator safely and automatically triggers the Monopolar Handpiece Output from an Electrosurgical Generator
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
