Philips - 21378A TEE
by Philips
The Philips 21378A is an omniplane III TEE ultrasound probe. The 21378A has a frequency range of 4.8 to 6 MHz and is compatible with a wide range of Philips ultrasound systems.
-hondatech739
Fri Nov 02 2018
Leakage current
Anyone know what the max leakage current is for the T6H? I have a customer who keeps saying her probes are failing the bite hole test. Reply
[list]    [*] Operating frequency 6- 4.8 MHz        Common errors of Philips 21378A TEE Probe include    [*] CW noise    [*] Color noise and artifacts    [*] Articulation failure    [*] Fails leakage test    [*] Fluid intrusion    [*] Motor control failure    [/list]
