Digital Detector
Completely re-engineered for higher performance in every way, the FDR D-EVO II provides versatility and peace of mind for your most demanding clinical needs. The detector's edges are smooth and tapered for easier positioning, it includes built-in image storage, an IPX-6 water resistance rating, and a Fujifilm exclusive antibacterial nano-coating.
FDR D-EVO II offers increased image sharpness and dose efficiency with new noise reduction circuitry. DQE and MTF are as much as 20% higher compared to traditional DR capture circuitry designs, making them the ideal solution for low dose exams and dose-lowering initiatives.
VIDEOS
Introducing Fujifilm's FDR D-EVO II
- New tapered design, easy to grasp, easy to slip under patient
- Magnesium alloy casing is extremely lightweight & durable
- Built-in memory simplifies trauma acquisition and shared use
- Smooth sealed surfaces lock out moisture (IPX-6 rating)
- Fujifilm’s exclusive Hydro AG™ antibacterial silver-ion coating is 99.99% effective against most common bacteria, 100 times* more effective than traditional coatings and 10,000 times* more effective than surfaces with no coating
- Fujifilm detector innovations improve image quality and dose efficiency through refined Dynamic Visualization™ processing combined with patented ISS technology and improved circuitry performance
SERIES MODELS
Height | 24 cm |
Length | 30 cm |
Weight | 3.3 lbs |
Width | 0.5 in |
Additional Specifications |
- Perfect for orthopedic, neonatal, pediatric and small body-part exams
- Combines dose and DQE benefits of cesium with patented ISS technology for maximum dose reduction and ultra-sharp image quality
- Ultra-lightweight
- IPX-6 water resistance rating, including removable battery
- Hydro AG antibacterial coating
- Durable magnesium alloy casing
- Exceptional imaging with improved dose efficiency
- Fits every neonatal isolette detector tray
- Extended battery life – standby time of up to 48 hrs. with deep sleep mode
- All FDR D-EVO II models utilize the same user-swappable battery type
- Can be used corded or wireless
- New Memory Mode allows on-demand sharing with any x-ray room or mobile
Height | 17 cm |
Length | 14 cm |
- Perfect for low dose exams and dose-lowering initiatives
- 14x17" weighs just 5.7 lbs. for easy carrying and positioning
- High-durability magnesium alloy casing
- Extended battery life – up to 36 hrs. standby time with deep sleep mode
- Color-coded LEDs confirm centering, connectivity, battery status and more
- Simple one-hand battery swap and instant reboot
- CsI models are currently available in 3 sizes: 14x17", 17x17" and 24x30cm
- All models use the same battery and can be used corded or wireless
Height | 17 in |
Length | 17 in |
Weight | 7.1 lbs |
- Maximized field of view, perfect for chest exams
- Fits standard buckys and holders
- Great for use in two-detector rooms
- Auto-trimming for off-center imaging
- Extended battery life – up to 36 hrs standby time with deep sleep mode
- Change battery with one hand and no re-calibration for battery swap
- Color-coded LEDs confirm centering, connectivity status and more
- Internal memory allows immediate acquisition for trauma and easy sharing and use with mobile and other rooms on demand
Height | 17 in |
Length | 14 in |
Weight | 5.7 lbs |
- Built-in memory allows immediate image acquisition for trauma, and sharing with mobiles and other rooms
- World’s first detector with antibacterial coating featuring Fujifilm’s exclusive Hydro AG
- Durable: World’s highest distributed load resistance, 683 lb.
- Tapered comfort edges for easy positioning and grasping from behind patient
- Fast, 1-3 sec. preview, 8-10 sec. cycle time
- Patented ISS detector technology improves DQE and MTF*
- Fits standard table and upright buckys and cassette holders
- Multi-charger holds up to 3 spare batteries
Height | 17 in |
Length | 17 in |
Weight | 7.1 lbs |
- Durable, magnesium alloy casing
- Extended battery life - up to 36 hrs standby time with deep sleep mode
- Multi-charger holds up to 3 batteries
- Color-coded LEDs confirm centering, connectivity, status and more
- All FDR D-EVO II models use the same battery type and can be used corded or wireless
