Fujifilm - FDR Go
by Fujifilm
Complete DR portable x-ray system
Get undreamed-of image quality in a complete DR portable x-ray system designed with technologists’ feedback. The FDR Go combines Fujifilm's renowned image technology, FDR D-EVO panels, with Dynamic Visualization™ for enhanced diagnostic visibility.            Built for speed and efficiency, the FDR Go incorporates features to ensure the safety of users and patients. A touch-sensing bumper stops the system and sounds an alarm if an obstacle comes too close, the quick release brake system stops the FDR Go whenever the grip handle is released, and a special safety mode allows it to travel at a slower speed for in room or training uses.
FORUMSView All (14)
-Cry
Fri Jan 17 2025
Error U4, U5 and U6
Hi guys! Futji FDR GO PLUS
I changed the main batteries, emergency break release batteries and CPU battery (WITH THE KEY TURNED OFF), I didn't know I have to change the CPU battery with the key ON. Now the machine doesn't capture the new date, and it displays error U4, U5 and U6 on every start up. Any help on how to correct this issue?
-Dean_Jay
Fri Nov 24 2023
Fujifilm FDR Go Forums
Hi Guys,
I bought the FujiFilm FDR go with no HDD, so no operating system and no drivers anyone to help?
Kind regards
Charles
-mike71
Sat Mar 25 2023
F57 error code
Does anyone know what this error code means. The batteries are not charging also.Reply
[list]      [*] Compact chassis size and low tube lockdown allow easy driving visibility and maneuverability in even the tightest spaces.      [*] Large touchscreen display with Fujifilm’s latest Dynamic Visualization™ image processing, which automatically optimizes images for greater diagnostic visibility      [*] Compatible with all FDR D-EVO wireless detectors available in GOS and CsI, in standard 14x17” or full field-of-view 17x17” sizes, and the unique wireless 24x30cm all featuring Fujifilm’s patented ISS technology for exceptional image quality at lower dose      [*] Dual, independent rear-wheel drive provides ultra-sensitive steering for smooth, quiet traveling and easy maneuvering in tight spaces.      [*] “Inching” controls at the tube head slowly move the system forward or backward for precise positioning at the bedside without needing to return to the drive handle.      [*] Long- and tall-reach telescopic arm features full angulations for easy and precise tube positioning.      [*] System battery power lasts 4-5 hours and features emergency reserve mode for additional exposures and travel after low battery warning.      [*] System can be operated wireless or with wired Ethernet connection utilizing standard DICOM connectivity and its ruggedized hard drive holds up to ~4,000 images.      [*] RIS shortcut button lets you close studies remotely from the mobile console.      [/list]
