Fujifilm - FDR Clinica
Clinical Confidence, Precision, and Optimal EfficiencyFujifilm is proud to announce our latest high-quality, cost-effective x-ray solution. The FDR Clinica Series of Components deliver a user-friendly, smart workflow for busy imaging professionals. Fujifilms renowned digital image processing expertise, including Dynamic Visualization, optimizes image display based on recognition of contrast levels throughout the entire exposure field. The resulting first-up images have outstanding detail and greater window and leveling capability in PACS. The FDR Clinica Series of Components are intended for use with FDR D-EVO detectors featuring Fujifilms proprietary Irradiated Side Sampling (ISS) technology, which positions its capture electronics (TFTs) at the irradiation side, in contrast to traditional detectors. This design significantly suppresses scattering and attenuation of X-ray signals, improving efficiency to produce sharper images at lower doses compared to traditional designs.
3Replies2 years ago | need help here! there is a error appearing when we turn on the machine an error occurs and the error code is E08.. what do you think is the problem or is the cause of that error?Reply |
0Replies4 years ago | Urgently need troublshooting guide or service manual Hello everyone. I would like to ask anyone if you have a service manual or troubleshooting guide for this Fujifilm FDR Smart x-ray system. My problem is that the function of the tabletop sensor is reversed and was wondering how to fix this? Thank you for sending me a troubleshooting guide or service manual. Reply |
Tilting Wall Stand
- A wide variety of exams can be performed using the optional tilting wall stand. Nonambulatory patients can be easily imaged in the seated position.
Dual-reference Rotation
- Both top- and center-reference rotation are available in our rotating tray, with automatic connection to the detector. The detector can be rotated while mounted in the tray with no need to remove and remount, greatly reducing handling.
Automatic Connection
- The detector cable and connector are built into the tray, enabling the detectors to be automatically connected when set in the tray. This new function greatly improves efficiency and provides a clean look with no need to manage cabling. The automatic connection to the detector keeps the battery charged in the event that wireless operation is required.
