Ultrasound Video EndoscopeEquipped with the ultra small Super CCD Chip Technology, these second generation scopes offer bright, vivid high-resolution endoscopic images, while the integration of ZONE Sonography™ and Sound Speed Correction technologies deliver delineation of high quality ultrasound images.
While the EG-530UR2 radial scope provides unique forward viewing, the design of the EG-530UT2 convex scope permits passage of therapeutic devices and needle position guide on the ultrasound image. These scopes are to be used in conjunction with the SU-1 Ultrasonic Processors.
SERIES MODELS
Length | 1550 mm total length |
Additional Specifications | [list]
Observation Range: 3 - 100 mm
Field of View: 140°
Distal end Diameter: 11.4 mm
Flexible Portion Diameter: 11.5 mm
Bending Capability:
-180° up/90° down
-100° left/100° right
Working Length: 1,250 mm
Scanning Mode: Color Doppler, Power Doppler, Pulse wave, B-Mode, M-Mode
Compatible Systems: EPX-4440HD, EPX-4400HD, EPX-4400, SU-1, Ultrasonic Processors
[/list] |
Observation range: 3 - 100mm
Field of view: 140°
Distal end diameter: 13.9mm
Flexible portion diameter: 12.1mm
Bending capability:
-160° up/160° down
-120° left/120° right
Working length: 1,250mm
Scanning mode: Color Doppler, Power Doppler, Pulse wave, B-Mode. M-Mode
Compatible Systems: EPX-4440HD, EPX-4400HD,EPX-4400, SU-1, Ultrasonic Processors
[/list] |
