Fujifilm - Standard Colonoscopes
by Fujifilm
Vision. Handling. Ergonomics. Speed. Service.
These core elements of endoscopy can be found in the design of every Colonoscope.    In addition to our reputation for outstanding HD imaging, our Colonoscopes are designed to make driving to the cecum easier and more comfortable for endoscopists due to a lighter control section, reduced angulation torque, and improved control body ergonomics. They also have stepped resilience from the distal tip to the proximal shaft, providing increased stiffness when approaching the hepatic flexure. Advanced construction and materials reduce the potential for mechanical breakdown and associated maintenance.        Ergonomically designed for efficiency and overall stress reduction, our Standard Colonoscopes come with a standard 12.8mm insertion tube diameter and either an extra-large 4.2mm working channel or a large 3.8mm working channel to offer greater flexibility in therapeutic treatment. A forward water jet function is incorporated for lavage in critical situations.
-QasemACT
Thu Sep 17 2020
issue in the colonoscope fujifilm model EC-530WL3
I have an issue in the colonoscope fujifilm model EC-530WL3. If I want To supply air, I stop the hole in the center of the Air/water button with a finger, but the air does not exit from the air nozzle at the distal end. But, when I removed the air/water valve and closed the hole by finger, the air exit from the air nozzle at the distal end. But if I put the air/water valve and stop the hole of the center of the air/water button with a finger, the air does not exit from the nozzle. So, please help me. What can i do? Reply
SERIES MODELS
Fujifilm - EC-530HL2
Fujifilm - EC-600HL
Fujifilm - EC-600WL
