Fujifilm - EC-450LP5
Vision. Handling. Ergonomics. Speed. Service.Fujifilm's Colonoscopes are designed to make driving to the cecum easier and more comfortable for endoscopists due to a lighter control section, reduced angulation torque, and improved control body ergonomics. They also have stepped resilience from the distal tip to the proximal shaft, providing increased stiffness when approaching the hepatic flexure. Advanced construction and materials reduce the potential for mechanical breakdown and associated maintenance.
- Slim outside diameter
- Generous working channel
- Light weight control sections with reduced torque mechanisms
Length | 1990 mm |
- Viewing direction: Forward
- Observation range: 3 - 100mm
- Field of view: 140°
- Distal end diameter: 11.0mm
- Flexible portion diameter: 11.1mm
- Bending capability:
> Up/Down - 180°/180°
> Left/Right - 160°/160° - Forcep channel diameter: 3.2mm
- Working length: 1,690mm
- Recommended System: EPX-4440HD
