Fujifilm - FDR D-EVO P-Series
by Fujifilm
Digital Detectors
FDR D-EVO panels are light, portable detectors that can quickly turn your x-ray room into a DR room with incredible versatility, allowing you to perform table and free cassette-based exams with ease. There’s also no need to re-work your existing equipment because FDR D-EVO fits existing standard Buckys and holders. FDR D-EVO P-series panels feature 150 micron pixel pitch and a wide 16-bit dynamic range, as well as Fujifilm’s exclusive, patented ISS (Irradiated Side Sampling) which provides ultra-sharp imaging with advanced dose efficiency. This exclusive design captures the x-ray image from the incident/patient side of the detector, in contrast to traditional designs which capture the image below the scintillator layer. The result is a reduction in the distance for light to spread, allowing the image to be captured where its sharper and stronger as it was always intended. Fujifilm is dedicated both to improving image quality and advancing dose lowering technologies and safe healthcare standards for patients. FDR D-EVO is a perfect example. It features engineering innovations which achieve dose efficiency improvements by as much as 30% compared to Fujifilm CR and as much as 20% over comparable DR detector designs, all while delivering exceptional images.
0Replies9 years ago | Irradiated Side Sampling (ISS) Technology - from Fujifilm Fujifilm's revolutionary ISS detector technology moves the TFT layer to the top of the conversion layer, reducing scatter and blur, and increasing sharpness and DQE. X-rays pass through a radiolucent TFT layer that reads the converted light where it's strongest and sharpest, resulting in sharper detail at lower doses. ISS also improves sharpness in Cesium Iodide detectors, sampling the light at the tips of the crystals, where the output is sharpest and strongest. ISS is used in Fujifilm Medical Systems FDR AcSelerate and FDR D-EVO detectors. Reply |
0Replies9 years ago | Fujifilm Direct and Computed Radiography Solutions Del Medical / Fujifilm Direct and Computed Radiography Solutions Reply |
