Fujifilm - FCR Prima T2
High Quality Digital X-rayCR Prima T2 has been designed for those private practitioners with low volume imaging environments. Small, light, fast, it has everything a smart private practice wants in digital x-ray.
The FCR Prima T2 stands out for its stunning combination of price, speed and remarkable image quality. Its throughput ranges from a rapid 47 to an outstanding 73 images per hour depending on cassette size. Its 100-micron images provide impressive resolution while Fujifilm’s processing technology ensures your first image is ideal. FCR Prima T2 is available with the FDX Console, Flash Lite IIP and FCRView workstations. The FDX Console is Fujifilm’s most cutting edge acquisition workstation, designed to streamline the operation of digital image acquisition products. It features Fujifilm’s most advanced image processing: Dynamic Visualization™. The Flash IIP Console is an innovative workstation that features powerful productivity-enhancing tools, enabling your staff members to operate more efficiently. The FCRView is a complete image management solution that provides users with a comprehensive set of tools to acquire, view and archive images all from one workstation.
FORUMSView All (42)
2Replies21 days ago | OFFLINE error code and there's a warning says on application FVS 1000 "THIS SYSTEM CANNOT BE USED ON YOUR COMPUTER USED IT ON DULY REGISTERED COMPUTER" anyone can you please help me with my problem I unplugged the ethernet cable from FUJIFILM FCR PRIMA T2 to the pc and I connect the pc to the internet lan then I troubleshoot the internet when I plugged again the ethernet cable from FUJIFILM FCR PRIMA T2 the machine say OFL and when I open the application there's a warning says "THIS SYSTEM CANNOT BE USED ON YOUR COMPUTER USED IT ON DULY REGISTERED COMPUTER" huhuhu please kindly help me :( Reply |
0Replies6 months ago | RU-Tool askes for License Key RU-Tool askes for License Key, please anyone can offer some help Reply |
1Reply8 months ago | error ME50613, QA00000 Fujifilm console advance, CR-ir392 There are such errors, what should I do? Reply |
- Total spectrum analysis for Fujifilm’s highest contrast display and detailed window and leveling visualizes images to be seen like never before.
- Multi-objective Frequency Processing (MFP) simultaneously applies varying degrees of contrast and spatial frequency enhancement to different-sized structures within the same image. This improves the visibility of both dense and peripheral tissue.
- Dynamic Range Control (DRC) improves visibility of both dense and peripheral tissue, which is essential for seeing through the mediastinum on chest exams.
- Flexible Noise Control (FNC) extracts noise data and suppresses noise levels from images without losing sharpness associated with diagnostic information.
- Grid Pattern Removal (GPR) (optional) automatically detects grid patterns and then uses a two-dimensional technique to remove them. This prevents the appearance of a moiré pattern, which can occur when using a stationary grid.
Length | 3.2 ft |
Weight | 86 lbs |
Width | 3.2 ft |
- Table top CR system
[/list]
