Fujifilm - FCR XL-2
by Fujifilm
It can process up to 94 images per hour - yet it fits right into small exam rooms or offices where space is limited. The FCR XL-2 can handle even the busiest periods in your office. The FCR XL-2 is capable of producing high resolution (50 micron) scans for 18x24cm and 24x30cm sizes, making it ideal for orthopedic and extremity applications where seeing fine detail is critical.
4RepliesWed Jan 26 2022 | Fuji CR XL-2 IP Cassette stuck error 10430 FujiFilm FCR XC-2 is there a way to manually remove stuck cassette. FCR XC-2 IP cassette stuck error 10430. Already performed shutdown. Update Figured out how to manually eject IP cassettes. Unscrew to rear screw top right corner & press eject lever behind plastic rear case. IP cassette ejects properly 1 out of 10 times using different size cassettes. Note: 2009 Fujifilm FCR is XC-2 not model mentioned above. Is there any service adjustment or cleaning that can resolve issue? Need Service manual for FCR XC-2 Thanks Steve Reply |
3RepliesSun Nov 14 2021 | fujifilm fcr-gx1-cr-ir364ru pls any one can help me i have fujifilm fcr-xg1-cr-ir346ru i have error no 10391 dust removeReply |
2RepliesFri Nov 08 2019 | manual i have a caplsula xl 2 . its giving me error codes 10466 kindly anyone help meReply |
[list] [*] Multi-objective Frequency Processing (MFP) simultaneously applies varying degrees of contrast and spatial frequency enhancement to different-sized structures within the same image. This improves the visibility of both dense and peripheral tissue. [*] Dynamic Range Control (DRC) improves visibility of both dense and peripheral tissue, which is essential for seeing through the mediastinum on chest exams. [*] Flexible Noise Control (FNC) extracts noise data and suppresses noise levels from images without losing sharpness and associated diagnostic information. [*] Grid Pattern Removal (GPR) automatically detects grid patterns, then uses a two-dimensional technique to remove them. This prevents the appearance of a moiré pattern, which can occur when using a stationary grid. [/list]
