Lakeside - 8288BF
by Lakeside
Low-heat-density electrothermal warming provides efficient and even heating. Maintain safe (3 F of current setting), accurate temperature levels.Dual compartments each have user-friendly electronic control with LED display to set and monitor temperature levels and lock settings to eliminate tampering. Separate safety override feature prevents overheating.5″ heavy-duty casters, 2 with brake, for quickly transporting or storing close at hand. Window in door allows you to easily monitor inventory level. Heavy-duty stainless steel exterior provides durability and ease of cleaning and sanitizing. Heavy-duty door handle and hinges withstand repeated use. Blanket-warming compartment – Adjustable temperature range of 98-200 F (37-93 C) for maximum patient comfort. Automatic on/off setting to conserve energy. 1 blue, epoxy-coated blanket support assembly. Fluid-warming compartment -Two operating modes ensure safe temperature levels for irrigation fluids, 98-150 F (37-66 C), or injection fluids, 98-104 F (37-40 C). Alarm alerts you if temperature changes 10 F (6 C) from current setting. White epoxy-coated wire baskets conveniently hold surgical fluids packaged in bags or bottles.
Height | 72.75 in |
Length | 26 in |
Weight | 531 lbs |
Width | 35.25 in |
