Lakeside - 8288BF-WW
by Lakeside
Independent temperature sensing system allows you to consistently provide the utmost in patient safety by remaining informed about exact fluid temperatures. Separate RTD probe for trusted accuracy and stability. Display shows the actual interior temperature (independently verified) versus the set temperature to quickly confirm proper operation. Dedicated microprocessor for a highly accurate PID temperature control and verification temperature sensing systems. Low-heat-density electrothermal warming provides efficient and even heating. Maintain safe (3 F of current setting), accurate temperature levels. Electronic control with LED display allows you to set and monitor temperature levels and lock settings to eliminate tampering. Two operating modes ensure safe temperature levels for irrigation fluids, 98-150 F (37-66 C), or injection fluids, 98-104 F (37-40 C). Separate safety override feature prevents overheating. Alarm alerts you if temperature changes 10 F (6 C) from current setting. Window door allows you to easily monitor inventory level. Heavy-duty stainless steel exterior provides durability and ease of cleaning and sanitizing. Heavy-duty handle and hinges withstand repeated use. White epoxy-coated wire baskets conveniently hold surgical fluids packaged in bags or bottles. Shown with optional
Height | 72.75 in |
Length | 26 in |
Weight | 531 lbs |
Width | 35.25 in |
