Washer/Decontaminator
The Lava 50 washer-disinfector line is ideal for small surgery centers and dental practices where it is used to clean and disinfect surgical instruments. Easy to install benchtop single door washers provide fast and effective treatment and a perfect preparation for sterilization. Operation is simple: load the material, close the door and select the cycle. The machine does the rest, thus minimizing risks associated with handling infected instruments.
- Washing and disinfection temperatures are fully adjustable up to 93°C
- Temperature controlled by means of two independent PT1000 probes
- Fresh water intake between each phase of the cycle promotes hygiene and better cleaning
- Three level water filtering system
- Heavy duty self-cleaning water circulation pump ensures rapid flow rate and effective spray pressure
- Powerful integrated filtered air drying system (only in Lava 50 DRS)
- Steam condenser prevents condensation from entering in the washing area Design and Convenience
- LED display with 3 adjustable washing programs
- RS232 printer connection for documenting washing phases
- One or two dosing pumps
- Self-cleaning chamber with rounded edges
SERIES MODELS
| Height | 535 mm |
| Length | 565 mm |
| Weight | 43 kg |
| Width | 500 mm |
| Additional Specifications | Basket Volume: 60 Liters |
| Height | 535 mm |
| Length | 575 mm |
| Weight | 46 kg |
| Width | 560 mm |
