Tuttnauer - 5075HSG D-Line
by Tuttnauer
Tuttnauer 5075HSG
The 5075HSG is a 160 liter fully featured stand-alone mobile pre & post vacuum autoclave. Many years of expertise with industrial sterilization technology have been packaged into the 5075HSG autoclave making it an ideal hospital grade autoclave. The 5075HSG is commonly used for fast cycles in small hospitals, medical centers and other mid-size healthcare facilities which need substantial loading capacity.
-Biomed77
Invalid Date
Service Manual
Need the SM ; to access and change Date to correct year..
Equipment: Tuttnauer - 5075HSG D-Line
[list]          [*] Mounted on wheels for easy mobility          [*] High throughput at a considerably low cost          [*] Autoclave chamber is surrounded by coiled jacket          [*] High volume water-ring vacuum pump    [*] Holds 2 trays    [/list]
Chamber Volume160 L
Internal Diameter500 mm
Height1660 mm
Length 1286 mm
OrientationFloor Standing
Weight366 kg
Chamber Depth750 mm
Width857 mm
Tray Dimensions:    > Small (mm): 310 x 21 x 698 (W x H x D)    > Large (mm): 310 x 21 x 698 (W x H x D)
