Tuttnauer - 66 Mid-Range Animal Care Autoclave
by Tuttnauer
Ideal for animal care applications
The autoclave operates with saturated steam as the sterilizing agent with a temperature range of 105 °C (221°F) to 138 °C (280 °F) and a working pressure that meets AMSE and PED requirements. Each autoclave model is available with either single or double door.            The 66 autoclave series is designed to cover a large field of applications for Animal Care and laboratories. The autoclave series has a chamber volume ranging in size from 340 to 760 liters.            Tuttnauer autoclaves are built to last longer, perform consistently, and comply with the strictest international standards. Autoclave chambers are constructed of long lasting 316L grade stainless steel with superior corrosion resistance. The chambers are fully jacketed for uniform heat distribution. The generator and piping are constructed of stainless steel. The pneumatic valves are air pressure operated, significantly reducing maintenance. We work to keep our autoclaves state of the art.
-luay
7 years ago
Service Manual
Hi every body, Does any body have a service manual for Tuttnauer 33120 EP ?? Help Please.Reply
[list]      [*] Single or double door      [*] ASME and PED compliant      [*] 316L stainless steel chamber      [*] For Animal Care applications            Door Safety      [*] A safety device prevents the operator from opening the door when chamber is pressurized      [*] Steam is not allowed into the chamber when the door is open      [*] A cycle will not start if the door is open or not properly closed      [*] The door cannot open until chamber pressure reaches room pressure      [*] Sliding Door Safety -The sliding door progress will automatically stop if an obstruction is detected      [*] Double Door Safety – interlocks prevent both doors from being opened simultaneously            General Safety      [*] Double Independent Monitoring: The combined digital and mechanical monitoring provides a cross reference and guarantees accurate results. The operator has two independent means to monitor temperature and pressure.      [*] Safety Valves: Both the chamber and the jacket are equipped with safety valves –if the pressure exceeds the allowed limit the safety valves will discharge.      [*] Built-in Steam Generator Safety: A water level monitoring system maintains a constant water level and ensures safe operation of the heaters.      [*] Emergency Shut-Off: Easily accessible emergency switches for immediate and safe shut down of the sterilizer.      [/list]
SERIES MODELS
Tuttnauer - 66120
Tuttnauer - 6671130
Tuttnauer - 6671162
Tuttnauer - 6690
