Physio-Control - Lifepak 20
Defibrillator
Using ADAPTIV biphasic technology, the LIFEPAK 20 Defibrillator/Monitor offers both manual and AED modes for hospital and clinic settings. The system offers both monitoring and therapeutic functions and can help hospitals meet standards of the Joint Commission on Accreditation of Healthcare Organizations (JCAHO) to have resuscitation services readily available throughout the hospital.
You’re committed to the highest standards of patient care in everything you do — including resuscitation services. Knowing this, Physio-Control, the world leader in defibrillation technology, designed the LIFEPAK 20 defibrillator/monitor with extensive input from clinicians around the world.
The LIFEPAK 20 is highly intuitive to use and adapts to various patient environments. It skillfully combines an AED function for the infrequent, BLS-trained responder, with manual capability so that ALS-trained clinicians can quickly and easily deliver advanced diagnostic and therapeutic care. It’s two defibrillators in one.
Simple yet sophisticated, the LIFEPAK 20 enables clinicians at every level to focus on the most important task at hand — saving a patient’s life.
The LIFEPAK 20 Defibrillator/Monitor: The smart, flexible answer to your hospital’s diverse defibrillation needs.
FORUMSView All (10)
1Replya year ago | My lifepak 20 fades to white after being on My lifepak 20 fades to white after being on and after i measure the volts according the service manual i found there are exchange on both capacitors c93 is 3.3v instead of 2.5v and c96 2.5v instead of 3.3v is there is an error in the service manual? is this the error ?if not then what will be the error?Reply |
1Replya year ago | service light on Hi, My device service led is on while there are no logs there. How can I solve this problem?Reply |
2Replies2 years ago | setup and service passwords What are the setup mode and service passwords for the lifepak 20?Reply |
SERVICE COMPANIESView All Defibrillator Companies
- Manual Mode
- AED Mode
- Setup Mode
- Service Mode
- Inservice Mode
- Archive Mode
- Auto Test Mode
Height | 21.3 in |
Length | 26.2 in |
Defibrillator Type | External, Automated (AED) |
Width | 26.2 in |
