I instal a fresh iip to windows 7 workstation with ver 8.3 after i open the program i got error 30151 can you help me with that
Mon Apr 28 2014
iip error 30151
Tue Apr 29 2014Reply from nca
hello my friend
look this
The dummy node is not set up.
Choose the Service Utility’s “Setup Configuration Item”, “NETWORK
CONFIG”, “HIS HOST (IIP)” to check for node setup. If no node is set up, set
DICOM Print SCU as a dummy node.
The DICOM Print option key need not be installed.
or look this too
When the OS is installed newly, be sure to initialize the image
database. If you start up the CL-AP without initializing the image
database, an error window opens
good look
