How do you adjust the Developer and Fixer temp settings from the factory set default of 34 degrees C. I need to set these temps to 30 degrees C to process some film with the correct density.
Wed Jun 04 2014
Developer/Fixer temp adjustment
Fri Jun 06 2014Reply from ricardsc2
Good morning,abaut your problem : inside of the head of every heather developper and fixer there are a regulator temperature to adjust to the desired temperature.
bes regards
ricard sanz cardiel
Wed Feb 04 2015Reply from emorgan
The developer is designed to run at specific tempatures. If you need a lower density, reduce your technique and dose.
