Metron QA-ES is being used to test device but cannot get REM to accept resistance. Initial problem was Bipolar doesnt give any reading. Any ideas about this issue or proper test setup?
Tue Jul 08 2014
Triad Failing REM Test
Tue Jul 08 2014Reply from Zac
Tue Jul 08 2014Reply from BioMedovation
If you have a problem with the unit, you might want to consider sending it to Image Quest for their flat rate repair price. They have successfully repaired many Force Triads for me and their repair cost is less than most boards or parts that I would replace in the unit. You can contact them at 1-855-813-8100
