Wed Jul 16 2014
AVS / Large Leak
Dear All.
I have a many SP2 system here, I faced same problem in many unit.
When I set the vt to 600 mL the Bellows dropped down more the 800 mL, it wasn't reach the top of cover.
When I did the Leak Test the message (Large Leak appeared), also some unit give me Outlet Blocked.
FYI: I have Penlon tools calibration Bags.
There is soem requlator inside the ventilator should be adjuested.
If any one face the same problems would you please help me.
Kind Regards,
Tue Sep 23 2014Reply from DRemus
Hi,
I'm a qualified service engineer. First you must locate failures causing scurgerea.apoi must rectify the fault, possibly faulty component replaced then you have made ??specific calubrare procedures.  remus82.dragan@yahoo.com
