Does anyone have a copy or tutorial of the process to hook up multiple 8015 IV pumps where you can test them through the computer. I stand to be corrected,but i believe you can have one brain and multiple modules and connect up to 4 0r 6 IV pumps via a data port hub?
Fri Dec 12 2014
PC software to hook up multiple Pumps
Thu Jan 18 2018Reply from Stan Skaggs
you can only have one controller and work on one head, but need to modules to do the PM work because one section requires two connected at a time. You can hook up as many controllers as you can connect serial ports though (bunch of USB connectors).
I have only gotten 4 going at one time though as timing has to be coordinated or you walk on yourself in moving from controller to controller in the software and working on the units. Any more than 4 and I get confused and lost.. I usually do two at a time in my Pump month normally.
mrstan.
