Fri Nov 11 2011
GE AMX 4 Multiple Errors
Unit Fails Test 4, Gives Check Sum Errors 6, 7, 10, 11.
Tried to calibrate Generator, but whenever any calibration is performed unit presents with Ram Readback Error when values are input.
Fri Nov 11 2011Reply from JC Killinger
JC Killinger
See posting http://www.medwrench.com/?community.posts/threadNo/4953/subject/Error-code/
In these cases check power/batteries then factory reset is usually the best bet.
Mon Sep 16 2013Reply from Wkrach
Make sure you are exiting the calibration properly. If you don't it will corrupt the cal data.
