Thu Jun 04 2009
Error code 152
Good Afternoon > > We have about 175 B/Braun Outlook 100ES pumps that were installed in > February. Over the past 60 days we have began to see these pumps coming > into our shop with "Error 152" on them. When this happens the pump has > lost its configurations and drug library. We are re-loading the pump > configurations. So far this week alone we have seen about 12 pumps with > this failure. Is anyone else experiencing this issue? Any input would be > greatly appreciated.
   RE: Infusion Pump Report Post
Thu Jun 04 2009Reply from Heathers
> We have 260 Bbruan outlook 100es IV pumps. I have at least four with that > problem a day. At least, after the weekend I had 13 yes 13 of them with > the 152 error. The company states that they have a fix for the loss of > config. They state they will be in to fix all the pumps at once. A couple > of other things you might want to look out for are 71 speaker errors. We a > getting a ton of these too. The screen blanks out on some of them to. > Watch the door bezel the pressure transducer is failing on alot of them. > The inner disk is pushed in then the pump will only read error. Each unit > is calibrated for each door, so if you have this problem then they will > have to put a half door bezel on it. Or they will send it to you if you > have a large number of them going bad, like we have. The last thing to > really look out for is that in the body weight area, some of them will say > cm instead of kg, I am not kidding it will say cm and not kg like it > should. These pumps > have been an issue for us. I would call Paul Navaro and talk directly to > him. I feel your pain and hope they fix these many problems soon. Feel > free to contact me if you have any questions and good luck.
Sat Jul 23 2022Reply from petergroft
Error Code 152 appears as a connection error in the game. The error message which shows it as a connection error does not explain enough, but the main reason behind Valorant Error Code 152 is something that's called an HWID ban (Hardware ID ban).
Hope This Helps,
Peter
