When scope is connected an set to auto light it has a strobe affect. It works fine on manual, but auto just keeps flickering. Bulb is new! Anyone run in to this before if so how did you fix? I have reseated connection and it went away for a period only to return.
Light source is Strobing
It happened to us before, I believe it was the ignitor.
I would give olympus a call.
1-800-848-9024
Thanks Gary, The shutter (thin metal piece in front of bulb) keeps bouncing up and down causing the strobe effect. Does the ignitor control this?
Olympus is anti-peopleotherthanthem-fixin stuff, so they do not let manuals or schematics out too often. You might be able to pry a digital copy from a sales rep, but that is hit or miss. Sounds like a controller issue, if my memory serves this can sometimes happen when there is an issue with the lite meter/sensor or associated board... just a guess however.
Calling Olympus is a good idea... maybe the holiday spirit will move them enough to provide some literature that actually will help you in repairing it.
Maybe I'm too late, have you checked the ( light control cable) between the light source and camera control cable?
