GE Fetal Monitor series 170, Marquette, to replace keypad membrane I need to access inside to unplug it...which screws??
or a schematic?
or a schematic?
4 screws on the underside, you'll need a #1 philips screwdriver with a minimum 3" shaft. 1st 2 screws you should be able to see, 3rd screw is under the speaker cover, 4th screw is under the tamper sticker(on mine at least)
