After turning on, error D7 appears and unit also can't move (jammed). Already changed FSR assembly left and right but problem is still not solved.
Mon Dec 05 2011
ERROR D7
Wed Feb 12 2014Reply from Frankie B.
yes it's a late reply but the problem can be for D4-D11 that when the key sawitch is turned on when a switch or lever is engaged. make sure you don't have a damaged switch or the handle isn't being pressed or jammed one way or the other. We had a problem years ago where the unit was pushed/bumped into a wall after the unit had being parked and had an error like this when they tried to move it. turned it off, moved it away manually from the wall and restarted, worked fine.
