On the log chart there are two separate incidents of temperature increasing and decreasing over an 8 hr period. Starting at -40 rising to 0 and decreasing back to -40. The unit is a Jewett(now Thermo Scientific)BPL 13 freezer. Any help with this issue would be great.
Wed Jun 24 2015
Temperature increasing
Sat Dec 19 2015Reply from Mohammad Ibrahim
Can you please specify at what set point was the refrigerator set ? If it was 0 ( which I doubt somebody could have done that ) , then I would suspect a bad compressor rely that could be Jammed in away that doesn't cut off the power to the compressor as it reaches the set point ! This is could be harmful and will lead to overloading the compressor to a point where you'll have to replace it .
